Seatbelt Swop!
oliross
Does anyone know if those blue citroen saxo seatbelts can be swopped for toyota yaris seatbelts? Or has anyone ever put harnesses in their yaris?
I'd be wary of changing the belts to something else unless you're going for the full harness option; the pre-tensioners, airbag etc are all linked and you might mess up something critical.
Lots of people have put harnesses in. If you do a search you'll find discussion on mounting options. You probably also need to disable the airbags though. You'll find info on this too by searching.
