185 With 205 Brakes
burfitt101
ive been hearing that you can use the front brakes from a st205 to upgrade the st185 brakes. is this right, if so how much of the system do you need to change and is it worth the hassle?
thanks for any reply
james
you can do it but it's not the easiest job, think it's www.gtfours.com that has the conversion, using brackets and spacers and all sorts. there is talk of someone making proper brackets on the GT4OC but there isn't even a first prototype out yet.
the rears are a straight swap tho ;)
you may end up having to change the wheels , due to the size of the front calipers. worth a mention. ;)
Did i read somewhere that scooby calipers fit??? :unsure:
Maybe i dreamt it. :)
GT4 BOOSTER... Welcome back mate. Hope you had a good holiday. :thumbsup:
i see alot of mangled scoobies around my area, is this down to !Removed! drivers or bad brakes ?????
thanks mate , had a good time came back well tanned , back to work tuesday :ffs:
Got a full set of st205 calipers if yr interested, just the rear passenger 1 needs new seal cos has v.slight leek!
i think i may find out abit more about the install first, thanks though...
james
