Changing Engines Starlet Life 2 Turbo?
i just purchased a 1997 model starlet life. i was
thinking of converting it into a turbo?? good idea
and if so whats the best ways of doing it? buy an
engine with turbo?
getting started so plz help!
Since you're in OZ, i doubt you'd have much trouble sourcing a Starlet Turbo. Just look online for a "front cut" which should have everything that you'd need to do the conversion.
TBH, I don't know much about starlets myself but if your car is a base model you'd probably be best to start with something better as you'd have to change a lot, brakes being the most important!
Post a bit more info about your own car and you might get some more informative responses!
