the 4efe can take a lot of boost as long as the tune is good and the revs are kept to a decient level, i have pushed the 4efe to 25psi but the fuel pump couldnt handle it and i was lucky not to break a piston, i have got a walbro 255 pump for it now so ill push it there again! i never rev the engine over 7000rpm, any more than this the rods will cry enough,
i have not compared 5e rods to 4e rods but i will do this very soon, but as long as the revs are kept down and the tune is good the engine will last for eva.
Dale
apparently the 5e rods are a bit thicker than the 4efte rods, but then again, the redline on a 5e is 5600rpm whereas you can go over 7000rpm on the 4efte, so i presume the 4e rods were built more to high revs
5efhe rods are bigger than 4efte rods, but 5efe rods are different to 5efhe rods,
i will compare the differences soon
d'oh yeah, my mistake
