Fuel Cut Defencer's
Hi guys,
Does anyone know where to get an FCD and boot controller for a good price for a REV 2 turbo?? I've been told you can get them for as little as £30, but don't know where. Fensport are about £90 + VAT for an FCD which seems alot of money! :o :o
Even this place http://www.greenline.jp/ is about £55 / 11,000 yen for an FCD. Apexi induction kits are only £55 too! But boost controllers are almost £300!?!??!
fuel cut defender
boost controller
these 2 are what i, and a lot of peeps on all mr2 forums have, cheap as chips, easyish to install and remove.
hth :thumbsup:
Cheers bud. :thumbsup:
Ordered the FCD and an Apexi Power Intake fliter/system, and will order that boost valve when they get in touch with me.
how do you know if youv got a fcd fitted? i think this may be the problem iv had with my car, cos im sure its putting out 14psi but sometimes holds back?? so this would be the standard fcd setting thats doing this yeh?
you know when u hit fuel cut its a large jolt and ur engine hates it
Can it hold back anywhere through the rev range???
I did notice last week that mine sort of stalled/hit a flat spot a couple of times between 5 & 6000 rpm on WOT. Would that have been the fuel cut kicking in??
