Technical Data Sheet For Super Custom
Hi, could anyone please supply the following information which I desperately need in order to register my vehicle in Portugal - I imported it into U.K. from Japan last year and did not need it for DVLA: Hi-ace Super Custom 1992 2.4L 8 seater - I need the HP figure and also the distance between the two axles. Hopefully someone out there can help me!
  • 1 year later...
Hi, I wonder if you could let me know if you managed to register your super custom in Portugal. I wish to register mine in France and will need a whole dossier of information, it would be a very valuable thing to make such info readily available for anyone else registering japanese super customs on UK plates in france, portugal etc.
  • 2 years later...
Hello!!!
Did you get any help on this request?
I'm having similar trouble!
I'm importing my HiAce 1992 campervan to Sweden and it needs tech info.
Any ideas??
I need horse power, tank capacity, max laden weight and max axel weight.
Same as you - mine was imported from Japan in 2006 and DVLA didn't need these figures, but the Swedes do!!
Hope you managed to get help and you're enjoying your HiAce in Portugal right now!!
If so, can point me in the right direction!
Thanks!
Emma
  • 2 months later...
  • 4 years later...
GENERAL Body type MV&1Box Drive FR Transmission Electronic control type 4 speed automatic (ECT) floor shift Displacement, cc 2446 Frame Q-LH100G-MFPQT Price of new car, thousands yen (Tokyo area) 3322 (~$27600) SPECIFICATION (SPECS)
EXTERIOR
Exterior dimensions (LxWxH), mm 4615 x 1690 x 1980 Interior dimensions (LxWxH), mm 3245 x 1525 x 1340 Wheel base, mm 2330 Treads (F/R), mm 1450 / 1430 Ground clearance, mm 170 Curb vehicle weight, kg 1950 Gross vehicle weight, kg Seating capacity, persons 7 Doors number 4 Min.turning radius, m 4.7 Fuel tank capacity, l 70
ENGINE
Displacement, cc 2446 Engine model 2L-TE Max.power (Net), kw(PS)/rpm 97 ps (71.34 kw) / 3800 rpm Max.torque(Net), N*m(kg*m)/rpm 24.5 kg*m (240.26 N*m) / 2400 rpm Power density 20.1 Engine type Water cooling serial 4 cylinder OHC turbo Engine information Fuel system EFI (electronic fuel injection) Turbocharger Turbo Fuel type Diesel LEV system (Low emission vehicle) No Compression ratio 21 Bore, mm 92 Stroke, mm 92 Final gear ratio Fuel consumption at 10-15 modes, l/100km Fuel consumption at 60 km/h, l/100km
CHASSIS / TRANSMISSION
Power steering Yes Tires size, front 205/70R14 93S Tires size rear 205/70R14 93s Braking system, front Ventilated disk Braking system, rear Drum (leading/trailing) Suspension system, front Wishbone type torsion bar spring (independent suspension) Suspension system, rear Trailing link axle type coil spring EQUIPMENT
EXTERIOR EQUIPMENT
Sunroof / Moonroof Special form roof Front fog lamp b.gif Rear fog lamp w.gif xenon headlight (Discharge lamp) w.gif Projector headlight w.gif Rear wiper b.gif Front spoiler w.gif Rear or roof spoiler w.gif ABS (Antilock brake system) w.gif TCS (Traction control system) w.gif LSD (Limited slip differential) w.gif Privacy glass w.gif UV cutting glass w.gif Aluminium wheel 14 inch standard
INTERIOR EQUIPMENT
Air conditioner Dual air conditioner Wood panel w.gif Cruise control w.gif Centralized door lock b.gif Power window b.gif Steering wheel telescopic b.gif Steering wheel tilt b.gif Leather steering wheel w.gif Power front seat b.gif Power rear seat w.gif Leather seat w.gif Falling down type rear seat w.gif Child seat fixed with seat belt w.gif Rear ELR3 point seat belt b.gif Front seat pretensioner seat belt w.gif Fourth limited front seat belt w.gif Side impact bar b.gif Airbag (Driver) w.gif Airbag (Passenger) w.gif Airbag (Side) w.gif Audio deck AM/FM radio equipped cassette player CD-player w.gif Car navigation system w.gif
b.gif - present w.gif - not present b-w.gif - option
