4age(non-tvis) And Carbs Question
CorollaGti
Hello,in order to install carbs at a non-tvis map sensored 4age do you need the ECU?because i heard that you need it and after the installation of the carbs....
the ecu takes 7 inputs from the engine and with those adjusts timing, fuel delivery etc etc so no you dont need the ECU as you wont have the injection system.
