i already have a turbo timer but i'm looking at putting a catch can is aswell.
has anybody else got one? are they easy to install? and where did they fit?
thanx
We have one on our n/a took all of 15 min's to fit, put it near the fuse box.
Think you would have to fit it around the same place.
what does a oil catch can do really?
An oil catch can prevents hot air and oil to get into the inlet system. The throttlebody stays clean and the inlet temperature drops. Lower inlet temperature = more horespower.
Our oil catch cans can be installed besided the fusebox in the engine comprtment.
The cans come incl. a airfilter and hoses.
JPMR2
and one more question, are the cheaper 'no make' ones any good compared to the 'make' ones?
They do the same job :thumbsup:
Our's cost about next to nothing on eBay :thumbsup:
only thing is over here in the U.K. you can't have the out pipe venting out to the air it as to go back to the engine. :thumbsup:
what difference does that make?
It's part of the M.O.T. Rules.
No fumes are allowed to fent to the air they must go through the engine to the exhaust.
so is it possible to 'forget' to connect it up like this until MOT time?
Yes you can put a filter on like J.P. said :rolleyes:
