Fitting A Rev Counter To A Yaris
digipulse2000
i have bought a rev counter from a dealer.
and tryed fitting it myself.
after looking around.
someone told me it is impossible to fit the rev counter onto the yaris.
without a converter.
because it has a dis system.
so i bought a converter from auto meter.
9117 tach adapter.
and had it fitted to the car.
when i went to pick up the car.
the person said that the coils on the top of the plugs are not pulling enougth juice.
to make the tach adapter work properly.
i just wanted to know if anybody has ever come across this problem.
or if they can recommend me a good rev counter that i can fit without any problem.
thanks.
any help is better then nothing.
there is the signal from the ECU for rev. It's a black wire with silver stripe on it. My car is Japan made and my ECU position may be different from yours. Someone from forum will help u for sure. It's quite simple to install. I will make a quick search and if I find smthing, will post again.
Cheers
Ismael
Hi again,
I have posted a pic for the ECU pins read out on the vitz-club forum (see link below). Have a look there to see the rpm gauges installed and the ECU read outs. Hope to have been of help. Gdluck.
Clicky !!!
Cheers
Ismael
