Brakes
m4rk scotland
i need new rear pads and disc so i thought i mite as well get upgradded jobbies nstead of stock, anyone have an idea of cost of four semi performance (black diamond) etc discs and pads? for each corner? probably green stuff pads or something you can recommend, i dont have 1000 quid for bigger callipers etc.
Personally, I wouldn't bother uprating the rears unless you do a lot of track days or have done some very serious engine mods. Mosy of your braking is done through the fronts - so they would be a better starting point for uprating.
Although if you are uprating the fronts it doesn't hurt to uprate the rears, but I certainly wouldn't uprate the rear whilst still running on stock fronts.
I use EBC Cross-drilled and grooved front discs, I do'nt know if they have made any difference to the braking , but they sound cool :rolleyes:
I think they were about £220 for the pair of fronts
