Quick Question
steve o
about a month i got a new set of alloys for my st202 and was woundering what pressure to keep the tyres at. the are 215/40zr17's.
:thumbsup:
Raise them by 2PSI over standard pressures. If you get any problems such as steering wheel shimmy or tyre scrub adjust them back to standard. But they should feel spot on. :thumbsup:
tyre pressures are given by the weight of the said vehicle , no matter how big or small the tyres or wheels fitted.
stick to standard you wont go far wrong.
I have simaler size tyres on 17's and I run 32psi and found this to be best as any less feels a little soggy in the corners.
Hope that helps ya
have a look on the post on drivers side door , should be a sticker telling you the pressures. :thumbsup:
