Now Whats Happend?
Right I was driving home down the M-way about 10 mins ago. I slipped the car into 4th and boosted! a few seconds later the was a jolt and a plume of smoke out the @rse end. Now the turbo won't boost AT ALL!!!
Has my turbo given up the ghost and finnaly died?? Or could it be something else??
I had a quick look (cos it's dark) useing torch light in the engine bay, and couldn't see any pipes that have come off.
Any ideas??? :help::help::help:
Sounds nasty fella, get your butt around to a garage tomorrow for a looksie, but if no pipes have come off then it could be the turbo :(
It does sound like the turbo - thats bad :(
any ideas what colour the smoke was? :unsure:
Sounds like the turbo has blown.....good excuse for a CT20B ;)
Cheers
KiwiMr2
shucks :( hope when this prob sorted mate its the last one for you for a good while
Temper tantrum!!-----¬
<-------------------------l
Not a clue what colour the smoke was, due to it being dark. All I could see was a stupid Saxo's headlights disappear briefly into a cloud of smoke.
My 2 now seems to have less power than my Diesel!!!
I can't hear it spinning up at just under 3k!!
Right. I've had the intake hoses off and the impeler seems to move round when I push it with my finger (althought not freely), I took a photo and it seems to be intact. Maybe the properler was obliterated, hence the jolt (as tho i'd lifted off the throttle quickly on full boost) and then that plume of smoke out the back end.
That would make sense wouldn't it? If the propeler isn't really there any more, then the impeler won't spin up cos it's on the same shaft and works off the propeler!
Yes, no, maybe??
What about the other propeller (exhaust side) ? There are two inside a turbo.... the exhaust prop powers the air intake prop.....
I've only looked at the intake side. How do you actually remove the turbo from the manifold?? Looks like a pig of a job!
This should help you click here :thumbsup:
A very good read. :thumbsup:
The exhaust propeller had been completely obliterated (I'll post a piccy of it 2moro). The guy found lots of bits in the CAT!! :lol: All sorted and back on the road now tho :yes::yes::yes::yes:
Same happened to mine, blew the whole exhaust side of,
damned ceramic turbos !,
hope u get her sorted soon, go for an uprated turbo, you wont regret it
Already had a standard CT26 put on.
Piccy of my old turbo!
