Sos
jonvagis
I have an avensis and i changed the motor into a 4a-ge 20V silvertop
and i have a problem with the temperature gauge.
The 4a-fe has 1 water sensor that goes to ECU and from there goes to temperature gauge
The 4a-ge has 2 water sensors from which one goes to ECU and the other one goes
directly to the gauge.
But the 4a-ge ECU does not have an output for temperature gauge.
The problem is that avensis' temperature gauge does not work if i connect it
directly to the second water sensor.
Does anyone have any solution ????
:help::help:
