Water Flowing Noise
aidy
I have recently bought a Celica T-sport, When i start the car as it fires up i can hear a water flushing noise for the first few seconds, also sometimes when the car is ticking over if i rev it it does it then, Is this normal because the last time I heard a noise like this it was ten years ago when i owned a Nova GTE and the water pump failed. Any info will be much appreciated <_<
It might be an airlock in the system, although they normally clear themselves after a short time. Is it coming from under the bonnet or under the dash (heater area)?
I doubt that it's a water pump failure, that would be quite rare on such a young car.
Hi, It seems to be coming from the heater area but its tricky to pin point, but i have noticed when the temp is set at a level which should be warm say 22 or 23C it seems to blow warm air and then slightly cooler air. The car is off in for a service in november so i will let them hunt for it.
