A/c And Econ ?
gavm99
Hi there,
I understand what my air conditioning does but what is the ECON button for??
Thanks.
Gavin.
Its Econonomy Air con. NO idea what the difference is........... boys were are you??????? :thumbsup:
I need educating. :unsure:
econ works in harmony with climate control and switches the air con on when the temperature rises above the pre set then off when it reaches the desired temperature - air con on normal or full runs constant and makes your interior a fridge
