1993 2.0 Gt - What Oil And How Often?
gavm99
Hi all,
Well I did end up buying the Celica and I love her!! I can't believe I have never gone for a Toyota before. Maybe 12 years old but drives sooooooooooo well! I want a newer Celica when I can afford it now!!
Anyway that’s enough bigging up the car. I want to change the oil having just purchased it for good measure. I want to know what oil I should put back in. The semi-synthetic stuff? How many litres will she need putting back in? How often should I then change it? Also where about is the drain point if I am lying underneath the car? Any special tools required for the drain point?
Thanks in advance.
Gavin.
depend on milage..go for a thicker viscosity if its over 100k!..plus do it about ever 4-5 thousand for a car you want to run forever..I do mine and it does make a huge difference!
