Engine Type
kirst_ie
Would anyone be able to tell me whre i can find out what model my engine is? :help:
Ive been told it should be on a sticker on the bulk head, in the engine bay, but i can see one :angry: .
If i rang toyota do you reckon thay would be able to tell me? :bookworm:
Thnk Folks :)
Ya toyota would be able to tell you if you went in to see them.
The information you are after is on the chassis plate however
If you pop the bonnet and look for the chassis plate it will be on there
Is it an import or a UK one
Its a UK one m8, ive looked on the plate in the engine bay, and all it has on it is the engine number and the chassis number.
I need to know asap as i wan to order some Iridium spark plug, but the company needs to know the engine model.
i would have thought that if you told them it's a standard UK ST202 2 litre they should be able to tell you what you need. Someone with more brains will probably be along soon who can tell you what it is however
The UK GT has the revision 3 3s-ge engine. Wherever you are getting these plugs from should be able to work that out from their guide books.
