Anyone Dropped A Petol Tank On A Gen 5 Gt?
mikeb
Has anyone done this job on a gen 5? Got any tips?
Since filling up last week my car has had a distinct whiff of petrol from the back of it. Actually, it's a total stench of petrol. :censor: I've had a quick look underneath and there are damp patches all across the back of the fuel tank, but I can't be sure exactly where it's coming from. It does look like it might be from the lip where the top and bottom halves join. :crybaby:
I don't know what caused it, but it suddenly happened after I filled up with petrol last week. I did totally brim it when I filled up, so I have a horrible feeling that the cold fuel has expanded as it warmed and raised the pressure in the tank until it found the weakest point.
Anyone breaking a gen 5? It looks like I will be needing a new tank. :crybaby:
Looks like it's going to be an expensive month - I desperately need four new tyres, and my insurance is due as well. I am planning to get the wheels refurbed whilst changing the tyres, luckily I have found someone who has offered to powder coat the wheels for £10 each. The leaking PAS pump will have to wait, and I think I might need a new CV joint sometime soon.
Cant help with the tank issue Mike. Tried The Celica club??? :unsure:
Sure i saw a tank on eBay as well. :thumbsup:
No. Sorry, It was for a 205 :(
Edited by daktari
Just had a poke about underneath, and it's definitely leaking from the seam where the two halves of the tank are joined. :crybaby: I've ordered a replacement tank from TCB (~£75). Looks like fitting it is going to be fun! :(
The flange on the rear of the tank is bent upwards, so it holds water and dirt inside it. I would advise people to check this on their own cars, and clean and apply waxoyl or underseal to prevent the corrosion.
Swapped the tank over to the replacement one the other week. Was quite a fiddly job, but would have been much easier with a 4 poster.
Anyway, here are a couple of photographs. First, the lip which holds moisture and causes the corrosion. I would recommend people get some underseal on theirs to stop it going like this:
This is a shot of the fuel pump and sender assembly, just for reference:
