I'm thinking of changing the automatic transmission fluid on my Sera. I can get a synthetic ATF from my Fiat dealer for a good price, has anyone changed the ATF on a Paseo / Starlet / Sera..?
Im sure Toyota recommend ATF D2 for their auto trans - be carefull if going to a fully synthetic oil as they can be incompatable when mixed with a mineral based oil, causing sludging etc and a knackered trans.
When changing the oil,you can only drain the oil in the transmission pan - not the oil in the Torque Convertor,so you can never get all the original oil out.
:thumbsup:
provided its Dextron II compatible it should work
