17" Alloys
corollagti16
hi ive found some 17" alloys 4 stud and have come off a mg zs the seller says should fit toyota, rover and a few others...
does any1 no if the will fit a corolla gti16 ???
thanks
I think they would fit, but surely your not going to put 17's on a corolla gti!? In my opinion,it would ruin the look of the car.
I'd go with some 15's, 16 at max.
got 17" superleggera's on mine and i think they look fine. check out my albums
If you fit 17inch you will need to roll the rear arch.
Also you can mess up the handeling (if standard set up) and will wear track arms quicker.
Personnally I'm not to keen on 17inch on GTi's (Dawsey: I don't mean to offend you, your vehicle is a completely different concept, you need bigger wheels to clear the brakes etc.). To me it doesn't look quite right.
