Front Struct Bar In Corolla E12
Toyosupra[pt]
which are the differences between before and after install front struct bar in corolla e12?
you recommend their installation?
And if i use original springs, the front struct bar increase something?
When you look at my site you olso see a Strutbrace from TTE and it helps :thumbsup:
Your site is in dutch, i don't understand :P
i already seen your photos, and TTE struct bar
,Oct 26 2005, 07:27 PM]
The Dutch language is so easy :thumbsup: ;)
the searching on some bad roads is very more less B)
acidman, this is front struct bar is better than yours? :bookworm:
this is Sparco
hmm , looks good , but looks even better when you paint your cylinder-cover im red ;)
And how is the performance , can you drive a curve 20kph faster than before :P :D
What's the price of it ?
that car is not mine :P
it costs 75€ ..
acidman, you know if you bar will fir in d4d models?
I would say : yes
I think the brake-fluid reservoir of the D4d is closer to the dashboard , so it isn't in the way of the strut bar. That's why the TTE strut bar doesn't fit in the diesel. (and also the one from Sparco)
