Torque Settings
bhinderharminder
hi,
i'am gonna change the brake pads on my e12 1.6 corolla, but dose anyonw know what the correct torque is when i tighten up the wheel nuts, also dose anyonw know jow long the brake Disc's last, the cars a 2002 with 18k on the clock and the disc's were skimmed 6months ago by toyota.
thanks
hi,
thanks
the discs are ok until they are grooved or warped.. :thumbsup:
hi,
thanks
I don't know if this is applicable to a 2002, but my '88 manual says:
Front caliper mounting bolts ............18 ft-lbs
Rear calier mounting bolts .............19 ft-lbs
Wheel Lug nuts ..............................76 ft-lbs
hope that helps
