2zz Engine Oil...
St3ve
Hi Guys,
Got no response in the Corolla section, so posting here to see if I get any help...
Which grade of oil do I need for my CTS? Is it 5-40, 10-40?
I would normally use 10-40 in my previous cars, but as this is a little different, I'm not sure...
Oh - I would have a look at the manual, if my car came with one :!Removed!:
Any help appreciated.
Steve
Make TOYOTA
Model Corolla 1.8 VVTi
Engine P
Year 2002-
Application Recommendation Capacity (ltr)
Engine (P) Castrol's best oil&nbspfor&nbspyour&nbspvehicle EDGE 0W-30 (j) 4.4
Alternative&nbsprecommendation GTX MAGNATEC 5W-30 (j)
Manual transmission SYNTRAX UNIVERSAL 2.3
Automatic Transmission
Differential(s) From Gearbox
Coolant ANTIFREEZE 6.7
Wheel Bearings LM GREASE
Brake Fluid RESPONSE DOT 4
Hide Notes Oil Change Intervals
Lubricant / Capacity Notes
j. 'Energy Conserving II' oils also suitable
General Notes
1. Power steering (where fitted except MR2): TQ DEXRON III, some older models: TQF. Refer to handbook. MR2: REFER TO MAIN DEALER
2. Engine oil viscosity recommendations (prior to model year 2000): 10W-30, 10W-50, 15W-40, 20W-40, 20W-50
3. Alternative recommendations, Engine, Petrol, MY >2000: <-29°C to 10°C, 5W-30 (exceptions: VVTi) VVTi: <-29°C to >38°C, 5W-30 -18°C to >38°C, 10W-30 -12°C to >38°C, 15W-40 -7°C to >38°C, 20W-50
4. Alternative recommendations, Engine, Diesel ,MY >1999: -35°C to 30°C, 0W-30 -30°C to 40°C, 5W-40 -25°C to 30°C, 5W-30 -20°C to 30°C, 10W-30 -20°C to 40°C, 10W-40 -15°C to 40°C, 15W-40 -20°C to 50°C, 10W-50 -15°C to 50°C, 15W-50 -5°C to 50°C, 20W-50
5. Additional manual gear oil recommendations: GL-4 may replace GL-5, 80W-90 may replace 75W-90 but latter strongly preferred in both instances
6. Additional differential oil recommendation: EPX 80W-90 may replace EPX 80W-90
7. Cooling systems. Use ANTIFREEZE at a concentration of 50% or one part ANTIFREEZE with one part water. Manufacturer's recommendation: Toyota Long Life coolant
From Castrols website CASTROL
5w-40 would be better than 10w-40 with winter coming on. 5w flows better than 10w (it's about 25% thinner on cold start) which means less engine wear in the log run.
Cheers
Simon
