94 Corolla 3door Gli
Notorious
hello there people im new on here... thought id c wot info i can gain...
i need a little help, if any1 drives a 93 - 97 Corolla GXi can u please tell me how the front fog lights work... as i drive a 94 corolla 1.3 i have just purchsed sum fogs lights out of a GXi model from the scrappers and there isnt a interior switch.
can any1 please shed sum light on my query ???
thanx
Affy
I've got a '93 GXI, the front fogs are turned on/off by a switch on the headlight/indicator stalk, same type switch as the intermittant wiper setting.
Hope That Helps :thumbsup:
Mike
hi,
thanx for that, i thought that would be the case of the fogs switch on the indicator stalk just wanted to make sure. ive got a 94 GLi model and just got hold of sum fogs from srappers thought id wire them up properly.
Driver side Braket is broken, is there anywhere u know i get hold of 1. ???
thanx.
affy
hi,
thanx.
affy
Unfortunately not, think the GXI is pretty rare to find another one too...
you sure your fog lights are in same place as the gxi? i think you might have a diffrent front bumper. check out my avatar pic you can see them at the bottom of my bumber. As for the bracket you will get one from toyota, ask s_mccullie or european_bob they both work for toyota.
