Hi
Does any body know how to remove the rear lights from the back door of a Previa 2005 model
I havent done this yet but it should be straight forward. youll need to remove the inner boot lid trim piece by opening up the boot, then the unit will most likely be bolted in from the back using either 8mm or 10mm nuts, remove these and pull the light off from the outside. It may be also stuck on with mastik.
Hi P!!GT
It's not that easy, I tried all that but on the inside edge of the door there is a plastic plug type thing and down the center is like a steel rod witch seems to be conected to the light from the outside but no head on it and no way of getting to it
