THERE IS OIL IN WATER...NO WATER IN OIL...ENGINE SPURTS UP WATER WHEN STARTING..CAR OVERHEATS WHEN ALL WATER IS PUSHED OUT OVERFLOW..ENGINE STRONG NO MISFIRE...WHAT IS EASIEST WAY TO TELL WHAT IS WRONG...TESTING RADIATOR SHOWS HYDROCARBONS GOING INTO RADIATOR.. :censor:
Sounds like head gasket to me...
However, what was the cause of the head gasket failure? Simply replacing the head gasket will not necessarily cure the problem. I'd make sure the fan is working and the thermostat is also functioning.
I have the parts if you need them.
