Fuel Filter
navygm
:help:
Hi
just wanted to ask where is located the fuel filter in the vitz 1.0lt?
went to toyota agent and wasn't of any help he just said under the back seat..got off the seat and found nothing to tell you that under, there was a filter :/
anyone can help? maybe with a pic?
thanks
I think someone said it was built into the fuel tank at the bottom but i may be wrong! im sure someone else will be along soon to answer!
you'r close enough woody, it is built in to the fuel pump which is inside the fuel tank.
:help:
Hi
thanks
Hello, Ihave the same kind car of you "toyota Vitz" Iasked the same question and now ai know that the filter it is built in to the fuel pump (inside the fuel tank).
I have a question for you; what kind of oil your motor vitz used?, I have a little problem and maybe I could change an other oil mark.
waiting your answer....... cdeza
:help:
Hi
thanks
for the engine oil I use BP Visco 2000 ( 15w40)
I think it's very good for it...as mechanics told me
Re the fuel filter....toyota agent told me that it;s under the back seat but couldnt find it...I've bought the fuel filter from them now I have to see where it fits
if there's any more help will appreciate. thanks
