Yaris Wheels
andyhiggins
:ffs: My wifes newly acquired Yaris T2 1 litre seems to have one 14" wheel at the rear and 3 13" wheels to complete the set. I have looked in the handbook for an exact spec on the wheel required but am not looking properly or it isnt there. Can any help with the spec as I have bought an incorrect wheel for a Polo years ago! Wife still reminds me of this! :P
Also any views on the best source for a replacement as I assume an odd wheel will not do the car any good in the long run? Is it the breakers???
Many thanks in advance!!
Andy :thumbsup:
As you know, should obviously be a 13" wheel.
There are sets often popping up on eBay, as well as breakers auctions, so you could contact them. They may not want to split the set though.
How come it's got mis-matched wheels?
Was it purchased from a dealer? If so, let them know.
Try searching the Yaris forum too, as I believe there are specs in there for the correct size wheel, etc.
standard size is 13" on a T2
any wheels with a offset of 38 and a PCD of 4x100 will fit.
13's, 14's or 15" wheels are fine
how about buying her a nice set of alloys
As long as you get the correct offset and pdc they will fit.. but you must also get the same "J" size as the other 3 rims.. it will be stamped on it somewhere.
It was the J size that I was after I am sure that a Toyota dealer would supply one but wow!!! the expense! :censor:
