Servicing Help Needed
ek4
new here and just need advice on servicing mums corolla. its k reg gli 4 door. dont know engine code just that its 1.6.
was serviced about 12-18 months ago (no idea what was done). its just driven round town 99% of its life and runs prety good. apart from oil, oil filter and air filter, what else should be changed and checked ? car is on 88500 miles
thanks in advance
Brakefluid , clutchfluid( is the same as brakefluid) gearboxoil,coolant,timingbelt.
:thumbsup:
might be worth changing the fuel filter too, HT leads check condition, power steering fluid (if u have it). I know as part of my last service at the toyota dealer they greased up any nuts or bolts or moving parts that needed it, plus u should get your brakes checked and check your shocks for leakage. What i used to do before i started servicing my car myself, I would take it to ATS and get them to do their ten point safety check then go get it serviced but i dont know if ATS still offer that for free anymore, been a few years since ive been there.
air filter is fine as just checked and clean, will do oil and filter, fuel filter, what spark plugs are needed and what should gap be ?
Buy the original sparkplugs by the dealer they are fine and the gap is fine already
do you know make and part no of oem plugs, i know toyota dealers rape when it comes to part prices so gonna be using local motor factor shop
Overhere in Holland they take a look in de computer when you give them your registration number of the car so that they can look over witch Car you are talking about to give the original parts maybe over there you may give them your Chassisnumber :thumbsup:
did the oil, oil filter, plugs, air filter, all other fluids look fine and are topped up. do think 1 or more shock has gone as knocking noise comin from around rear.
what is oil capacity for this car ? im guessin around 4 litres (used around 3.5 as unsure but will top up tommorow)
is it ok to use optimax ? just want to run £5-10 to give insides a good clean. dont want to use other stuff you can get of shelf (oil and fuel treatment in case it damages gaskets/seals)
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
