I've just got the car for a run about plus i like the fact its got a big boot -
I'm not mechanically minded so I'm sure theirs a perfectly good explanation as to why my Carina is drinking oil like I drink Stella!! it also seems a bit heavey on fuel its a 1.6 XL
A wet and dry Compression Test will tell you if the rings/bores are worn and causing high oil consumption - Toyota state the maximum oil consumption is 1 litre per 1000 miles( which is a lot ).
If its a Carina E, then:
You could start by removing the EFI fuse for 30 seconds( in the fuse box next to the battery) to clear any codes in the ECU, give the car a 10 mile run and check for any fault codes stored in the ECU.
If you do not know how to check the ECU for fault codes - go to :
http://www.troublecodes.net/Toyota/.
If no codes are present, then give the engine a service,
Change the spark plugs,air filter,fuel filter and engine oil+filter.
Get a tin of carb.cleaner and clean the INSIDE of the Throttle Body and throttle butterfly and check the breather hoses are clear.
Hope some of this helps.
:thumbsup:
Ok thanks mate I'll check that out
