Help - St200 And 202 Info Needed...
Harvey-aw11
Does anyone know what setup these had for the front brakes?
My theory is the ST (1.8 ST200) used ~260mm discs with single pot calipers, while the GT (2.0 3sge st202) used ~280mm with twin pot calipers. Can anyone confirm/ put me right?
Thanks;
Harvey
i believe that you are correct, as to my knowledge the 1.8, 2.0 and 2.0Turbo all had diffrent pads based on the performance of the engines. So i guess the discs are diffrent also, i know the GT4 disks are a lot bigger than the 1.8 and 2.0 gt.
