Rear Heater Matrix
mrfil13
Hi, its back to the time of year that every window mists up in the morning and you can't see. My rear window heater has never worked since i got it, so i decided to check it out. The fuse isnt broken, if you open the boot and use a testing lamp to connect the 2 side elements together it works, so basically theres a current going up the sides, but the bars them sleves dont seem to be working. Any ideas, it seems they are in parrallel so one broken bar should not affect it.
Any ideas or experiance with this?
