How Do I Remove My Stereo / Centre Console?
funkyg
Title says it all really. How d'you do it?
I'm getting an iPod in a few days and I want to find out which CD changer adapter I need to buy, and then moving on actually fit it.
My car is a 2001 CDX Saloon. I have taken out the ash tray and pulled the wood surround. I've pulled the entire console out by about an inch and now I can't do anything else. How do you pull it out all the way?
Thanks guys.
Mike.
i did the same as urself, and it popped out, then unsrewwed the bracket holding the radio/tape player in for my aftermarket one..
So im stumped to what else u can do really
You did first thing.. Second thing You must to pull up entire console for release two pin on the back of console.. it's easy.. But need a little try..
try sliding it up about 1/2 an inch,, the white clips'll breaks if ya don't because the metla bracket they go into have a wider square secion at the top, you should be ok then
Cheers guys. It was the "lift the whole thing up" bit I didn't know about. Sorted!
Thanks again,
Mike.
