Cleaning The Maf
IceHz
I came across couple of articles sarching on google that suggest using an electronic cleaner to get rid of the dirt.
anybody out here done it? if so what did you use.
Cheers.
k
i would have to say to use a cleaner with alcohol in it, as it will evaporate and clean at the same time.
I don't know if anything stronger will damage it or not.
Hmm... thats what Toyota used last time I got it cleaned from them, but some ppl recommend not to use it or electrical contact cleaners as they leave residue on the sensors.
electronics cleaners OTH doesn't leave anything behind (as in residue.... hopefully the sensors will remain intact!) or 99% pure isopropyl... which is kinda hard to find here. Maybe I'll check out the contents of electronics cleaner & see how it is.
BTW what on earth is a "pish cleaner" :unsure:
Thanks guys
:thumbsup:
