Gen 6 Servicing?
bountyhunter
Hi guys,
Can anyone tell me exactly what would be needed for a 80k service on a Imported Gen 6 GT. The cambelt was done about 10k ago so that is fine.
I would prefer to go to a local garage as opposed to Mr T so what would i need to get and where should i get it?
Also what is the best oil to use ive been recomended Gtx magantex, mobileline and valveoline which one is the best that would help my engine. :help:
Cheers guys
any good oil if you change it regular , toyotas oil is ok at 4000 miles intervals for what it costs 11 quid and 7 for an oil filter.4000 miles being my own personnal time to change it.
maybe have the brakes checked and new pads fitted if they are worn ,have the gearbox oil drained and renewed. i find with servicing alot of things done which garages are good at is CHECK THINGS ie a 117 point check .5 points = tyre wear ,5 points = tyre pressures.it all ends up being just a quick check and little is changed , we as motorists want things changed for our pound notes .this is why i do all my own work for the time it takes. :yes::thumbsup:
