4afe Info
lowlux
hi i'm new here and am after any info on the 4afe i wanted to know if it possable to convert it to fit in a rear wheel drive vechical and what vechical i would need to get the box out of and is there an adaptor kit to move the dizzy so i won't hit on the fire wall any info would be great
thanks heaps
lowlux
Thats an unlikely conversion! As in most people want to know about the 20v or the 4agze. I think the 20v gearbox and the 4afe box are evry similar apart from 1st/2nd but do hook together..
mostly a real wheel drive conversion is done with the 4age out of the ae86 which is already set up for the angles, dont know if anything is available for the 4afe, where the dizzy and airbox are concerned..
Most of this is documented better in Australia than the UK....
cheers,
Kamran
i was told that the block form the 4age and the 4afe where the same
and do you know of any australian toyota forums
thanks
Thats right 4a - Bottom end ge - topend and the fe & ge heads are intrechange able. Well almost that simple ;) you would need a ecu and maybe a loom too
