Head Light Issue
Nightstalker
Lo every body Peeps...!
Has anyone found condensation on the insides of the new avensis esssess headlights...is this normal :unsure:
I heard from the cougar site I used to go to that with ford they say its a fault and you get the light assembley changed under warranty...wonder if Toyota do the same.... :rolleyes:
Yes I’ve started to get condensation in the front head lamps as well as one of my fogs. One of the fogs has already been changed under warranty for this problem. I will be contacting Toyota next week to get both my head lights replaced under warranty. My wife’s corolla had this problem and both head lights were changed, no problem. Good luck.
Common fault (and one that should have been rectified by now).
Both headlights on my Avensis replaced within 1 month of new.
Have had four new fog lights under warranty due to misting up. Dealer said they must have had a bad batch of lights. So far no trouble with the headlights thank goodness.
