Rear Badges
viperroom_112
Hi guys ,
Could someone please tell me the best way to remove all the badges on the back of my yaris. Is it difficult ? and is there any products I need to buy to make removal as clean and smooth as possible ?
Cheers Guys :thumbsup:
David
DO NOT USE A SCREWDRIVER you'll scratch your paint
use either dental floss or fishing wire, start from the top and work your way down cutting through the glue/stickyfoam.
Mine didn't need heating up first I just cut behind them with some dantal floss.
Then you'll need a bit of methalated spirits to wipe the glue off, this requires a lot of work to get the glue off.
Then I gave it a coat of wax and wiped it off.
Sometimes you may see the outline of where tha badges were, just use some more wax or polish a few times and it will go.
ALSO do not try and peel it off :blink: ur likly to pull laq or even worse some paint off
while ur heating it up add some slight pressure from side to side to soften the glue up, for mine i used some dental floss and sliced it off as such, cutting away the glue behind!! :thumbsup:
done it with fishing line..
worked like a charm..
do it that way.. i even didnt heat it up..
but then again.. ive done it when i had it for 4 months new from the dealer.. so.. i dont know
I got my mums hairdryer out, applied some heat to 1 Badge at a time (not too much mind you) and got some dental floss and cut through it with that. Once its behind the Badge just use a sawing action/motion and it should come away quite easily! :thumbsup:
You can still see where my Yaris Badge was in certain lights (although very rarely) and I've polished it about a million times.
A kettle of hot water and some gentle persuation and they were gone
Along with a T cut and polish with a couple of layers of wax for the full car :B
I pulled mine off with fishing wire, It was really hard and took ages...
When I finaly got it of, I found out why it was tough,
I cut right through the pegs that fit into the holes. LOL :o
So I ordered some new badges from eBay and stuck them all back on.
It was fun whilst it lasted.
Blimey, I didn't realise some were pinned on at the rear. :o
I took mine off with the hairdryer and floss method. Also found a small bit of lighter fluid on some tissue helped get off any glue residue - wash the area off as soon as poss though to get rid of the fluid. Then wax/polish when you can for more protection :thumbsup:
