Standard Head Unit
j.a.kelly
Hello...
searched and cant find so new post time!!
Now we managed to find our 2nd Yaris T-sport we upgrading the Speakers..
slight issue is that i dont know which wires are which...its a p2... has anybody got a list of what wires are what?
ie. front left +/- etc... hope some1 can help..
also... the dash Speakers are 10cm correct? can you go to 13cm without mods or not?
thanks
JK
Alright mate easiest way i found was as follows;
Yes, thespeakers are 4" = 10cm. When changing em, i found it easiest to undo the bolt near the windscreen with a small socket set. when youve undone the bolts/screws, you'll see the wires attached the the speaker. Look at the bottom of tghe speaker and note (on a piece of paper or something similar) which one is positive and negative for each speaker (cos i don't remember from the top of my head). Then just hook the wires up to the new Speakers, using the 'chart' you've made for which wire goes where. Bolt the Speakers back in and you're done. HTH!!
excellent...
will have the missuses steresrted in no time!
Toyota do so many things so right, but they get the stereo n Speakers so unbelievably wrong dont they!?
JK
