Boost Measurements / Readings
I have a Greddy mechanical boost gauge (in Bar)
Now i used this when I first fitted my MBC to set the boost.
Now I have a HKS Boost conrtoller (EVC 5) which has a screen and reads boost in kpa.
Now i know that 14.8 ish psi is 1 bar
But what is kpa compared to psi / bar ? only ask as want to know if my greddy / HKS read out is more acurate !
HKS has the reader in the engine bay, and is a digi display
Greddy is a vacume pipe from the engine bay to my dash.
But how do i convert kpa to psi / bar ?
1.0 Bar is 1.0197 kg/cm which is 14.5 psi, which is 100 kpa :)
I know the bar, psi, and kg/cm are right....to convert from kPa to psi, multiply the number by 0.145. As for your example, 1020 kPa = 148 psi.
Cheers
KiwiMR2
