Starts Then Stops
micky3
Ok please help i have a avensis 1.8 Sreg 1999 and it will not start!
i turn the key it fires up goes up to 2000 rpm then back down to 1000rpm and cuts off.
it just started doing it and can not think why!
it sparks
it has fuel
it has full charge
it got new sparkplugs just in case
i have tryed all 3 keys
but it has fallen out with me
can anyone help
don't know it is parked under my house and has to come up 1 floor to the outside.
can not push it it is too steep! need to have it pulled out but then it it don't start i need to get it back under! its to hard!
When you manage to start it next time, put your foot on the throttle and hold the revs at approx 2-2500rpm straight after it has started.
Does it cough or splutter?
It's propably a vacuum hose come off or split
If not then it could possibly by either dirty or contaminated fuel or a blocked air filter/fuel filter
I was just thinking it could be a fuel supply problem which you could eliminate if it stays running on a bump
A bit of Googling gives me . . .
1.Vacuum leak
2.leaking EGR valve
3.Air filter / fuel filter clogged
4.Fuel pump not delivering enough fuel
5.Leaking head gasket
6.Timing belt
7.Camshaft lobes worn
8. ECU
if i keep my foot down it still cuts out, fuel is getting in nice, air filter is new, had filter off and on but still will not run with or with out and toyota will not help with out seeing it. thanx for the help but i think i am flufed.
i have 2 more avensis 1 Rreg and 1 Sreg and want to take the ecu off one and try that but don't know if it will lose its memory???????????????
just out of interest, what engine is it? Maybe we could focus our attention a little more then.
