Antifreeze Into Screenwasher... Help...
KevT3
HI all,
I have just done something really stupid, I poured about 200ml engine antifreeze liquid into the screenwasher liquid container...
Does that matter? I know it's pretty serious if I did the other way round....
Kev
Depends how diluted it is. A lot of washer fluids actually contain anti freeze. Not too sure how diluted it would be though. You might be as well draining the washer tank and starting again. :thumbsup:
How do I drain it??
stick a hose pipe in and let it over fill for 10 mins
Or pull the hose off under the bonnet and push the button to spray the windscreen :thumbsup:
Can anyone show me a picture of the host under the bonnet? I don't wanna end up pulling off a random host :)
And is it easy to put it back in place?
Thx
Kevin
Its that little Hose thats hooked on the windscreensprayer that sits through the motorhood.
I,am going to the Motor Show Essen in Germany now . send me youre emailadres because i don,t now how to put pictures on here and i will send some pics tonight :thumbsup:
jo.dekroon@home.nl
Kev..get a long plastic tube..stick one end into washer bottle....suck the other end until liquid is near to top then bend it over and it will all syphon out....might not taste nice tho'. :rolleyes:
With Anti-Freeze. I wouldn't. You can get a syphon pump for a few quid at Halfords or any other motor shop.
And make sure you get it all out, and flush the bottle thoroughly. Anti Freeze can strip paint, so you don't want to be spraying it on your screen no matter how diluted it is.
Thx people,
