just wanted to know can a rev3 turbo engine go straight into a rev2 turbo car
for a rev3 turbo engine whats a rough price for one of these and is fitting expensive
Yes.
Call Rogue Systems or 3S for engine swaps :thumbsup:
I thought the ECU and wiring loom are different !
no AFM on a rev3 tubby (it has a MAP)
im sure the ECU pinouts are different also, but i think the physical engine fits the same !!
The engine itself will fit without any problems. The ECU's are different tho. If you keep the Rev2 ECU the Rev3 engine won't run higher than 5,500rpm because of compatability reasons. You'll need the ECU from the 3 as well.
