Powering A Sub?
guydraper
ANY HELP!! HIGHLY APPRECIATED!!!
I NEED TO RUN A WIRE FROM MY Battery. WHERE IS THERE A HOLE THAT I CAN RUN THE LEADS THOUGH (FROM ENGINE INTO CAR)??
+ ANY OTHER GOOD TIPS FOR WIRING TO AN AMP WHICH IS POWERING A SUB AND 2 6*9's
(one more thing. i've bought a rear speaker wiring loom like someone told me. but it powers the rear Speakers that i'm adding and the 'rear speakers' that were custom fit.. down by my feet on the door when driving.. ANYONE KNOW HOW TO FIX IT SO BOTH FRONTS ARE FRONTS AND REAR ARE MY SUB AND 6*9's
CHEERS FOR HELP
DRAPER
under your bonnet on the right hand side there is a rubber grommet or whatever you want to call it take your wire through there and under the sills to the rear of the car.
as for the wiring of the Speakers you may need to cut a few wires and connect them back up the way you need them
