Rear Speakers And Ampli: Some Questions
svarionman
Hi, i've a Yaris (first serie) and now i want to change the original headunit with a cd/mp3 player, if it's possible i also wish to install 2 rear Speakers (now i've 4 anterior speakers). I've seen that all cd players only support 4 Speakers, so have i to install an ampli to put the other two Speakers or there's another way to do it?
Anybody of you have done this and can tell me how much will cost ampli+2speakers+installation?
Thank you
EDIT: maybe i've found myself the solution: i think that on yaris the 4 anterior Speakers are two tweeters and two woofers, so it's like they are two Speakers and there is place for the another two for the rear...it's that right?
there are two tweeters and two mids but yeah im pretty sure they use all four speaker outputs between them! What you need is an adapter from your local toyota garage that allows all those four Speakers to be plugged into the two front outputs and then you can plug others into the rear slots!
If you do a search on this site im sure you will find lots of information!
