Fuel Cut Defencer & Manual Boost Controller
TOYMOTA
:help: Has anyone, or can anyone take a piccy of their FCD for me please? I want to fit mine this weekend and Haven't got any instructions as to where it goes, and what wires it plugs into. Will I need to use a soldering iron?
Also a pic of which pipe your MBC is plugged into? :help:
Thanks. :yes:
i wouldnt fit them till you've got a good boost gague first. the boost controler goes on the pipe that comes off of your turbo and goes onto your wastegate. as for the FCD i'm sure someone else has the diagrams to hand
FCD goes to the ECU, and yeah, wire snippers and a soldering iron needed.
MBC goes between turbo and actuator. You'll need a lot of hose.
Yer, I fitted a boost gauge a month or so ago. Running at 10.5psi at the mo. I want to up it to about 14psi.
So to fi the MBC will I have to get under the car to do it or not? Pics??
If you don't know I wouldn't attempt it.
Get someone local to fit it, watch them do it, then help the next person out ;)
