Group Buy, Rps Clutches...
Jesus
RPS Max Street Series Clutch
If you have the power, this is your clutch!! Turboclutch MAX Series clutches have powered many of the fastest cars down the track for the past 10 years. This is a proven winner that has been perfected over the years to become the standard it is today.
MAX pressure plates offer 400 to 600 pounds of extra clamping force to hold your biggest power. 9 second Supra’s, 10 second 300ZX’s and 3000GT VR4’s, 10 second Honda’s and Eclipse’s all use Turboclutch MAX!
RPS is the only clutch company with a U.S. Patent (#5,769,973) on their single diaphragm pressure plate technology. Our unique dual diaphragm technology allows us to create almost any clutch unit with any pressure ranging from stock to double stock in 100 pound increments. If the stock pressure is 1400 pounds we can make MAX pressure plates 1800, 1900, 2000, and so on up to 2800 pounds. This flexibility can only be found at RPS.
RPS’s all new PRO MAX Series is the last pressure plate you will ever have to buy. This pressure plate uses our patented (10,334,633) segmented heat shield design that helps prevent warpage and is replaceable for the life of your car. If you ever wear out this pressure plate simply replace the segmented heat shields and you’re good to go. These replacement shields sell for a fraction of the cost of a new pressure plate. The PRO MAX is ideal for drag racing applications where short clutch life is the cost of going fast and RPS is helping reduce that cost.
I've contacted SRB Power (UK distributor of RPS clutches) and arranged 20% off if I can get 10 people together for this clutch.
It's rated to 450lb/ft torque, yet still remains driveable due to being organic.
The clutch costs approximately £294 + VAT normally... which is cheap considering what you're getting... and then we can get a further 20% off if there's enough of us.
Please add your name to this thread if your are seriously interested.
Please note that the clutch kit does not come with a release bearing. This part from Toyota costs £21 + VAT for the MR2 Turbo.
Offer is open to other forums, so if you know anyone on other forums, please point this offer out to them.
