Buying A Supra
firestorm30
I am looking to buy a supra.........I have recently looked at a great model, although when it was started up, there was white smoke coming from the exhaust.... People have told me to look out for this problem........
Any advice on things to look out for and things to avoid when buying a supra?
Many thanks
What year supra??
Being a little more specific helps people help you ;)
Buying guide
Most supra's emit white steam from the exhaust in this sort of weather. It's a big 3.0 car with a big exhaust system, as long as the smoke clears after the first 5mins or so it should be OK.
If you had a load of white smoke on a hot summers day, now that's another issue :D
turbo or n/a?
Non turbo version, the white smoke thing is bothering me, as the car was inside, not outside and was running for about 10 minutes.......
Walk away if you have doubts, supra's arent exactly scarce...let alone non turbo ones :yes:
