:help: Hiya i have a 92 J previa GL and ive got a problem with reversing when i reverse when cold its fine but when i reverse it when the engine warms up i have to REV it to about 3000rpm before it kicks you up the spine then there is sign of movement.... :crybaby: i have to watch where a park now cause i have no reverse...please can someone :bookworm: look it up for me would be great.... :thumbsup:
  • 3 months later...
:eek: have you checked the kick down cable as the cable went on mrs previa she has no reverse now as
was not spoted untill to late hope this helps?
peteski
: :help: is there anyone that can tell me(previa 90 modal)
:crybaby: i have fitted a auto box filled with oil tested it had no drive
:crybaby: so took it back out fitted the old torque converter filled with oil still no joy
:ffs: im running out of ideas
. the place i got gearbox from said it was fine but not having worked
on many autobox motors i need a little :help:
