Strange Sound When Pressing Down The Clutch
jay dh
ive not noticed this sound before, might be normal but it sounds like a soft scraping sound, kind of like when you hit full lock with the steering wheel. happens each time i press the clutch, not a loud, nasty sound though.
i cant make out of its a normal sound or not, is it?
Jay
Could be the pedal scraping on something? or the metal bit the pedals connected to catching someone (maybe bent a bit out of shape from use?)
Just spray all the joints in the footwell and engine bay with appropriate grease... WD40 is the quick solution but won't last forever!
i got the same problem but my squeeks, i was told its the clutch slave cosing it.
i took it to mr t i think they sprayed wd40 on it, it helps a little then it comes back again
well mine, was making a strange noise, like an old door, it seemed like a haunted clutch :lol: took him to toyota (which over here seems like a crazy people's house, everybody running like ants) went in, they had the hood openned for 5min with the surgeon operating inside, and it came as new :P
